Asus p8p67 Offset Setting Help
Italiano86
I wanted to lower my voltage on my 2500k which is set to 4500mhz so I am using a negative offset which is currently set at .070 which seem high, but it works. Thing is, the bios shows this setting as red, which begins at .065. Is there a danger of undervolting if this setting is red? I am thinking this is only if using a positive offset value .065 and above.
The chip idles at .944 and loads at 1.296v. I have pll overvoltage enabled and the phase settings at their second highest. Other than setting the voltage at manual, using this high offset seems like the only way to keep the voltage down.
What is your setting for Load Line Calibration? At high settings it actually adds voltage at load, so with offset mode it is often advisable to try using Regular (because you are using a high offset to take away voltage that LLC is adding). You might find that Regular and an offset closer to zero has a better overall result).
I have it set to ultra high, which is 75% I believe. I'll set it to regular and see how much lower it goes.
I set the load line to regular and now have the offset at .05. The idle voltage is now higher at 1v exactly and fluctuates sometimes down to .988, while load is now at 1.272-1.280 and seems to be stable for the time being. Also, pll overvoltage is disabled. Not sure what that is supposed to to exactly.
I guess this would be the best setup for the time being, I don't think the idle voltage will go much lower, which really doesn't matter, since crazily enough the load voltage is down and is just as stable from the previous 1.296v, which is cool with me.
If it does crash all I can do is go from -.05 to auto, and if this is the case, will the voltage jump up again on auto? I suppose I can set it to +.05 and still have it be relatively low? Thanks again for the help man.
Auto should still be relatively low. PLL overvoltage is normally only needed if you exceed 4.5 - 4.6, and using it makes S3 sleep not work, so best to keep it off if possible.
no its needed when you go over 1.4which is around 5Ghz to stabilize it. Otherwise it must be off.
Don't know why people mess with all the settings in the bios. Just put the ratio on whatever you aim for eg 4.5Ghz = 45 then increase the vcore by 0.025 till it passes on prime. Simple everything else on auto
This is based on CPU, and isn't a hard and fast rule.
I know someone who can run at 5.3 ghz with PLL off (x53 cpu), and his vcore is 1.5 something.
There is a poor chap in the gigabyte tweaktown forums who needs to turn on PLL overvoltage for x45 for 4500 mhz! But his chip is stable at 1.35v. With PLL disabled, he can't boot at x45, regardless of voltage.
So that PLL on for 1.4v does not apply. The multiplier wall is based on CPU, not on voltage.
I ended up setting the offset to + .05 which is working well, load is back to 1.288 which is where it was when I had the -.7 value. Pll overvoltage is off and load line is on regular also, so far so good.
People mess with settings spoony to figure out what works. It's super easy to manually set the voltage, but if you prefer a nice and cool idle core speed and voltage then there is a fair amount of trial and error involved.
I think this chip can easily hit 5ghz, but don't need it. Not worth having to set the voltage to 1.35+. My gtx470 is going to be the main bottleneck of this system for a long time, and until then, 4.5ghz is sweet. :D
then they're boards are fucked up. Pll is 1.4v to stabilize it. under that its useless.
yes that's understandable but what I mean how can you start tinkering with it when you don't know what your max ratio is?
I see people fiddling with it with a ratio on auto. once you get you max ratio. Then you can fine tune it by fiddling with it. They must remember intel gave them the microscode late and not everything so its trail and error with all these small bios tuning settings. But with all the ratio is the same and correct.
I don't know where you are coming up with this 1.4V stuff. PLL overvoltage has nothing to do with the voltage required, and everything to do with the multiplier.
But don't take it from me and everyone else on the forum (except you) - here's a quote from Asus about it:
This option / value is “ Intel PPL Overvoltage” this option furthers multiplier scaling considerably.*
A D2 sample with peak multiplier of 44 with PPL option enabled and corresponding voltage applied we have seen results of a stable 50 multiplier now able to post / boot and be held. ( previously without the PLL value the same CPU would failed to compelte a boot with a any multi exceeding 45 )
