bigdogchris
- Feb 19, 2008
In the past I've tried to install 7x64 onto my SSD as a GPT disk, but have failed. In lieu of this post in the OS forum, I've decided to experiment again, but am still failing. Let me walk you through what I'm doing so you can spot where I am making a mistake.
- I take a hard drive and zero it off.
- I verify my installation USB is FAT32 and has the .efi boot files
- I boot to my installation media and select UEFI:USB from the boot menu.
- In the hard drive installation screen, I see unallocated disk.
- I press Shift+F10 to bring up command prompt
- I type list disk and find my hard drive as disk 0
- I type select disk 0
- I type convert GPT
- Disk has been successfully converted to GPT
- I type list disk again and verify the * is under the GPT column for the hard drive.
- I exit diskpart, then close command prompt.
- I refresh, then choose unallocated space and press next.
- I wind up at a Windows desktop and view the hard drive in Disk management to see that it is MBR.
