Asus P7P55D... settings for stock i7 860
Jumpem
Do I need to set values for voltages, memory, CPU, etc by hand or will the default "auto" settings leave evrything at proper values?
Nubbleet
Default SHOULD set them, but make sure your RAM is set to the correct speed/timings/voltage.
Juan_Jose
ASUS Technical Marketing Specialist
Yes the bios will auto apply all voltages ( keep in mind though if your memory is over 1333 such as 1600 ) you will need to use docp or xmp to have it at the rated frequency. If you are not concerned with and do not plan on overclocking your system you can use the auto defaults without issues. As always if you have not updated your bios i would advise the update to bios 711. Hope this helps and please enjoy the rest of your day.
