ASUS P7P55D-E SATA controllers?
SirJohn
I just bought this board last weekend at Microcenter with an i7-860. I put the rig together and attached two Seagate 1TB to the first two SATA ports (of the 6 near the one jmicron controller SATA port). I then attached the two optical drives to the top ports (Marvell).
When I tried to boot for the first time, the BIOS would stop at "configuring marvell controller" for a long time and then nothing. I was unable to even enter the setup. I heard no beeps because the case didn't seem to come with a speaker?!?
So I cleared CMOS, still the same. Finally I moved the opticals to SATA 3 and 4 and it booted normally and allowed me to both enter BIOS and boot to DVD.
Can someone explain why this occurred? What do I have to do to make use of these Marvell controller ports?
I am still waiting for a 64-bit Win 7 DVD so I haven't tried anything else yet.
Also, this is my first build in 6 years so I am a bit rusty. If anyone has suggestions on how to set up my drives most efficiently I would appreciate hearing from you. I originally thought of RAID 1 then setting two partition, one 250GB and the other 750GB, then had second thoughts. Maybe simpler is better? The board also has a legacy IDE drive but will I gain anything by using it? I may decide to re-work things when SSD becomes more affordable.
I am especially interested in the 1 jmicron and 2 Marvell ports. What is the purpose for these? I know the Marvells are the high speed ports, but since I have mechanical HDs they are not much use to me yet.
FYI I have about 500GB of data I want to move to the PC after its set up.
Specs are:
Antec 300 case
Antec Earthwatts 650 PS
P7P55D-E ASUS mobo
2x2GB OCZ DDR3 1600
i7-860 processor
XFX 5770 ATI card
Seagate 1TB x 2
2 SATA optical drives
make sure that all the correct controllers are enabled in bios. also that you have the correct controller mode set, ie acpi, acpi + ide, raid, legacy ide, etc.
you really should get another drive for boot/aps. then set up your 1tb drives in raid 1, without partitions. you can buy a really fast 500/640gb drive for $55 to $70 now. also, the intel 40gb ssd is on sale for around $100, or at least it was over the weekend.
i am going to go with a 30 or 40gb ssd for my os and favorite game/s and apps, then either 1 80gb vraptor or 2 80gb in raid 0 for the rest of my games and apps, then a raid 1 or 5 array for my data.
i wouldnt use the ide port unless i had to.
I see, so I would have to initially boot from the SATA port 1 and then move the opticals after the controller for Marvell is enabled. I have to check on that.
I don't think I can get away with a small OS drive. I have an 80GB on my old PC and it's about 60GB full just with programs. Yeah I suppose I could install on the data drives but then I have to worry about drive letters changing. And aren't larger mechanical drives faster because the data is more dense on the platters?
OK so say I go with your idea, which SATA ports/controllers should I use for which drives for best efficiency?
Is it possible to use the 2 SATA 6 (Marvell) ports for booting (say when I upgrade to SSD)?
Wouldn't it be best to spread my SATA devices accross all controllers to reduce bottlenecks?
Thanks for the reply.
John
Not that anyone else seems to care, but I got an official answer (of sorts) from ASUS support:
My question:
I am confused by the SATA ports. What are recommended usage for jmicron and
Marvell controllers? I tried putting Optical drives on Marvel ports and could not boot
(hung at configuring Marvell controller at POST).
Seems I am safe just using SATA ports 1 to 6 but then what good are jmicon and
Marvell ports?
Please tell me the most optimal configuration. I have two 1TB mechanical hard drives
and two SATA optical drives.
ASUS answer:
"that controller is normally for secondary hard drives (data hard drives) normally my bootable and dvd drives will be on the intel controller"
