I need some help cuz I'm gonna build a new pc including these two components: an Asus P55 mobo and the famous Noctua NH-D14 fan to cool a Core i5.
As those Noctua cpu coolers (3-pin connector) doesn't support the PWM function that has the 4-pin connector in the motherboard, I'd like to know if the mobo will be able to control the NH-D14 fan speed automatically, based on the cpu load and temperature, so that it doesn't matter if I choose either a PWM or non-PWM cooler. Or will it work at full speed all the time, no matter what I do?
In the FAQ for this fan model at the Noctua website, it says that you can connect the non-PWM 3-pin fan to the 4-pin connector in some mobos and they are automatically regulated, but I guess that's not in all mobos. Do Asus mobos support this?
What are the advantatges of PWM fans if they supposedly can be regulated automatically by voltage as well?
Thanks
Thanks
