Asus P6T won't POST
Stoopid Guy
Hi,
I have just put together a new build with:
CPU: i7 920 w/ stock hsf
mobo: Asus P6T X58
GPU: Sapphire 4850 X2 2GB (also tested with brand new evga 7200GS pci-e)
PSU: Coolmax 700w
RAM: OCZ 6gb DDR3 OCZ3G1333LV6GK
The system will start up -- fans whirring, lights on, but absolutely nothing appears on my monitor. I've tested the monitor and it works. I've tried plugging the monitor into all four of the DVI ports on the video card, and with my spare video card, and it doesn't work in either of those cases. There are no beeps during startup (I've made sure the system speaker is connected). I have connected the 8-pin CPU power connector as well as the 24-pin mobo power connector, and when I have the 4850 X2, I've had both of its power ports plugged in as well.
Initially, I tried the system in some thermaltake case, but I now have it on cardboard to rule out any weird grounding issues. I've cleared the CMOS several times, run the system variously without RAM or without a video card or without both, trying to get the motherboard to beep at me. I've replaced the CMOS battery with a new one. Nothing has changed. I have no other pci-E, i7 or DDR3-compatible motherboards or systems around, so I can't test these parts individually on other computers. As I understand it, this pretty much means that the motherboard was DOA and I should RMA it? Are there any possibilities for things I can try that I've overlooked?
Thanks a lot!
Have you confirmed any of the other components (PSU, RAM, CPU, etc.) to be working? It probably is the motherboard, although if you have access to another computer that you can use to test some of your parts, then I would recommend that you do so.
when you pulled the ram out, did the computer give you the beep code or just sit there?
I agree with Zero to start testing all the components that you can.
Try reseating the CPU, maybe something stupid happened and it isn't mounted properly.
