Asus P6T - USB Port Problem
olscarlett
I am having a SERIOUS problem with my usb ports. Weird thing is it only happens when playing Call of Duty WaW. My keyboard starts shorting out as well as my headphones getting a popping sound in them. I have downloaded the driver updates, I think they were the latest ones, they were the only ones I found. I do not know what else to do besides throw my brand new custom built computer out the window. And seeing as how I would not like to waste 2000 I would like to know if anyone knows what the problem is because the maker is oblivious. Thank you guys.
Does this happen to all the ports or just one in particular?
I have moved the keyboard, headset and mouse to all different usb ports on the tower and it does the exact same thing.
You may want to check that non of your cables are exposed and could be causing some type of short or also picking up interference. If you assembled the system you self in some rare situations you can see possible issues with mismount causing a number of the issues you have described. Additionally if you have installed express gate you may want to check if within that enviorment you can duplicate the issues you are having.
I did not build it myself. It was Cyberpower. I know they did a shotty job on the build because half of the stuff was not plugged in correctly and some of the stuff does not work. I will be calling them tomorrow.
