ASUS P6T Deluxe V2
FLYINGDOG
I will be receving this board monday and I would like to know what I could expect overclocking wise with a 920 do and the ifx-14 and 2 190 cfm delta fans.
3.8-4GHz or higher probably, if you know what you're doing. And two 190CFM Deltas? You better bring ear protection.
Damn, 3.8-4!? I have a rampage II extreme coming tomorrow.
The rampage can probably do 3.8 stable, right? With liquid cooling?
Pretty much any of the name-brand X58 motherboards will be able to hit well over 4.0 on good air. With good liquid, the sky is the limit!
omg theman, youre 'theman'.
Do you mind listing your hardware? I just bought 12GB of OCZ Platinum memory. With that, and i7, a HX620 PSU, rampage II, and watercooling, could I do that also, you think?
lol this is awesome, I cant wait to put together my system this weekend!
But yea, what hardware do you have? And what setting did you use? Manual? AI CPU Level?
I've been reading the manual :)
Ouch, I've been reading your temps. Theyre in the 60's and 70's. Is that normal? Its 'safe'?
I'm guessing you didnt use AI Cpu Level now.. I'm guessing you manually overclocked.
lol ai cpu level
overclocking manual is the only way to get the most out of you chip.
all hardware
i7 920 D0
RAMPAGE II EXTREME
MUSHKIN 7/8/7/20 1600 AT 7/7/720/1710
ill finish the rest i have to leave for work
Damn, I was so excited about the Cpu Level feature. Guess Ill have to stick with manual.
And damn again, I was about to get the mushkin instead of the platinums for 40.00 more.
Yeah, thanks 'theman', Im looking forward to your other settings after you get home. Cant wait!!
ok here is the full rundown
i7 920 D0
RAMPAGE II EXTREME
WD 1TB black
6800 XT
COOMAX 950W (great PSU btw and great customer service)
COOLERMASTER STACKER 830
WATERCOOLING SETUP
PRIMOCHILL THYPHOON III W/ SWIFTECH MCP655
HEATKILLER 3.0 LT
HW Labs Black Ice Pro III Triple 120mm
3 65 cfm fans
SETTINGS FOR MY OVERCLOCK
cpu ratio 21
bclk 215
vcore 1.38750
qpi 1.38125
everything else is auto in the bios
dram voltage 1.656
Thanks, youre awesome theman!!! Cant wait to try it out. Deciding to build it tonight, or to build it after my 4870 card comes.
I'm doing 4.0ghz on air with a TRUE and a single 120mm Xigmatek (probably more like 60cfm)
Temps aren't really my limit (I hit mid 70's) but even after raising volts from 1.25 to 1.35 temps only raise a few degrees but can't really get it stable past 4.0, but I haven't touched QPI voltage either, I think it's still at 1.35
do you have a c0/c1 chip?
