Asus P6T Deluxe Issue
doox00
It appears once my 2nd 260 comes for sli I won't be able to use my pci x-fi xtrememusic card, as the only 2 pci slots this board has are in between the two pci-e slots used for sli.. hmm
Will he still be able to run the videocards at 16x and 16x, or will adding a PCI-E audio card in use up some of the 32 channels effectively forcing his SLI rig into 16x and 8x respectively?
The X58 chipset has 36 PCI-E lanes. A PCI-E sound card will only use one, which still leaves 32 graphics lanes and 3 lanes for other PCI-E devices.
mobo hardware like gigE and raid controllers can use up a few lanes, if the mobo only leaves 32 free then adding a 3rd card will throtttle the 2nd GPU. Something I'm wondering, how hard would it be to change the standard so that in PCIe 3.0 if you had to split 32 lanes among three cards 16/15/1 would be an option.
The only time it'll drop bandwidth is if you use the 3rd PCI-e x16 slot on the bottom, otherwise your all clear to put a PCI-e X-Fi card.
Also you can still use your card, the 2nd PCI slot is still accessible even with 2 GTX 280s.
That is good to know..I was about to blow a gasket myself after reading this. I had not even thought you would not be able to fit a PCI soundcard with SLI.
I wondered if it would fit, if it does it will be a REALLY tight fit though.
You'll have plenty of room :)
