Asus P5WDG2 WS PRO
Hi im having a little issue with some settings and i can not figure out whats missing =(
I am using the P5WDG2 WS PRO with a Geforce 8800GTS and an Audigy 4 sound card.
This are the only changes i have made into the bios:
1) HD audio controller: Disabled
2) PCI Lan: Disabled
3) Marvell SATA Controller: Disabled
4) Onboard 1394 Controller: Disabled
5) BIOS EHCI Hand-off: Disabled
6) USB 2.0 Controller: Disabled
7) Legacy USB Support: Disabled
When i go in system properties>hardware>device manager there is a yellow mark that says "Input Device" and under it it says " Unknown Device". I have tryed to enable and disable other things into the BIOS but this doesnt go away and i cant figure out whats missing.
Any help will appreciated thx.
