Asus P5W DH - Memory Issue
you have to go into the bios, and set the overclocking to manual, then go into advanced chipset settings -- then Put manual at the configure DRAM spd timing
The top 4 in the picture correspond to the 4-4-4-12 timings that are common on higher end memory. The actual memory speed is somewhere else (DDR2 800, etc.).
You have to go to the Advanced tab and then look under JumperFree Configuration.
It is set on auto by defult and needs to be changed to manual. Once you change it that will will open up the other options to adjust FSB, voltages, and memory speeds.
