asus p5w dh deluxe Help.
Foosa
I recently updated my bios because I was having some issues with my onboard wireless adapter.(fixed that problem) After I updated to the new bios my e6600 has been clock at 2.13ghz instead of the rated 2.44ghz. I have been messing around with it for awhile, I could up the cpu frequency and get the clock, but something else is not right and I don't know what. That would be more of a work around then a fix.
Settings
BIOS 2406
cpu frequency 266 (same settings I had with old bios and had 2.44ghz)
DRAM frequency is set to ddr2 800 ( i have corsair Xms2 ddr2800)
Vcore is auto
memory voltage is auto
cpu clock is 2.13ghz
should be 2.44ghz
if you need more information just ask and I'll give it.
Go into the cpu settings and disable the C1E and cpuTM(?) options. I think you are just seeing the power savings feature.
