ASUS P5Q PRO
-SHiFT-
Going to be getting a P5Q pro soon, and I noticed the MOSFETs north of the CPU socket are not heatsinked.
Planning on grabbing a Thermalright HR-09 Type 2 cooler for it, but the problem is I don't know whether to get a U shaped, or S shaped sink.
My CPU cooler is a Noctua NH-U12P.
Here's an image if you need to take a look at it. Due to motherboard orientation the MOSFETs are directly to the RIGHT of the CPU socket in the below image, but when the motherboard is installed it will be NORTH of the CPU cooler.
Just wondering whether or not there will be clearance issues with the NH-U12P.
http://gallery.techarena.in/data/513/Asus-P5Q-Pro.jpg
Unless you're planning on some serious extreme overclocking, you don't need to put a heatsink there. I'm running my Q9550 at 3.8GHz and I've never had heat issues with those components.
Alright, was about to ask whether those needed to be cooled at all.
I noticed that the Gigabyte EP45-UD3R and UD3P have those MOSFET's cooled.
Even the P5Q Vanilla has those cooled abelit with aluminum sinks and not copper ones like the P5Q Pro.
Alright, I guess it should be okay since my case has what I consider decent air flow.
