Asus P5Q Pro fan headers
  • Thread starter Deleted member 72990
  • Start date
D
Guest
I would like to connect 4 120 mm fans to my compupter, and the only means i have of doing it are by a pair of 3 pin fan headers on thoe mobo. I was thinking of using a y adapter to connect 2 fans per header. The fans are very low speed (nexus). Is it okay to connect it this way?
It should be okay as long as the fans don't draw too much current. But you don't have any 3-pin to molex adapters? Buying and using some of those would be preferable to splitting out your mobo headers.
Well, let's just say that I made my computer cables so nice and tidy that the molex connectors are hidden away and out of reach, and can't really access them without taking apart half of the PC. It's a fairly compact HTPC case and everything is hard to get to.
Thanks for the input.
