Asus P5Q Pro Bios revision question
Zake202
I'm running 1306 bios atm.
Wondering if I should flash it to something newer?
I have my Q6600 OC'd to 3.4 and I'd hate to reset everything. I can't remember if settings like that save or if I should even bother flashing it?
Flashing the BIOS will reset everything. Also as a rule of thumb, unless the BIOS update fixes an issue you currently have you should just stick with your current BIOS version. The only other reason you may want to upgrade is a possibility of better OCing potential. Although I haven't heard of any one revision of the BIOS that OC's better than any other with the P5Q.
