Hello every one,
I just purchased this board (ASUS P5ND2-SLI Deluxe) with Pentium 4 650 and Corsair 5400UL memory and was trying to overclock it, but have some issues doing so.
Everything went smoothly with the memory: set it to 3-2-2-7-7 1-Clock and voltage to 2.1V.
With the processor I increase FSB to 840Mhz and the total speed of it is 3.57GHz, but it only shows that speed during the POST.
When I booted into the OS (Windows XP Pro SP2) the processor speed is still at 3.4GHz!
I tried all kind of different things but no luck to see the speed of 3.57GHz in CPU-Z or in SiSoftSandra.
Every POSTing shows the correct CPU and memory settings after different increases of the CPU speed, and the memory stays at the 3-2-2-7-7 - 1T.
So with the FSB for cpu was 840MHz the CPU POSTed at 3.57GHz and the memory stayed at 675MHz. Once I boot to windows, ASUS AI Booster utility shows up and it states that speed (3.57GHz for the CPU and 675MHz for memory) but only for about 10 seconds. After that it resets it to 3.4GHz for the CPU but keeps the memory settings mentioned above.
That looked kind of weird to me.
The same story repeats for every single attempt to overclock the cpu beyond its stock speed no matter how SMALL or BIG the increase was. The memory stays at those aggressive settings.
vCore showed 1.37 - 1.42
So I don't know if the problem is in BIOS or not. I am afraid there is some kind of flag in BIOS that I need to disable in order to see the speed I set. First I thought it was Intel-SpeedStep, so I disabled it and got the same results.
Here are the settings that I got in BIOS:
Overclocking mode: Manual
Frequency control: CPU/Memory independent (840MHz -FSB, 675MHz - Memory) Intel Speed Step: Disabled.
Is there anything that I forget to set so that I will see the correct speed in Windows?
I also talked to ASUS tech support and they are investigating it right now.
If anyone has an idea what is going on with my board/cpu please let me know, i'd appreciate it.
Also if anyone has the similar setup, please let me know if you had any success to get higher cpu speed than its stock speed.
Thanks.
Kaz
My RIG:
P4 650 - 3.4GHz with ZALMAN 7000 cooler
Corsair XMS2 DDR2 5400UL (3-2-2-8) 1GB
2 x XFX 6800GT PCI-E in SLI
2 x Hitachi T7K250 SATA2 160GB on nVidia RAID Striped
1 x WD3200JD SATA on nVidia
3 x Optical Drives: Plextor 716A, ASUS 616-DVD, ASUS -CDRW
PC Power and Cooling 510-SLI PSU
Thanks.
Kaz
My RIG:
