Asus P5N32, Thoughts? Question about Audio
Punkrulz
Hey guys,
I have been speccing out this new computer for a little while now. My friend has turned me onto the Asus P5N32-E SLI. It seems to be a nice looking board, and the price isn't that bad either. I'm really anxious to start building it. One of my questions though:
I really dislike the audio panel on that, it sticks out like a sore thumb. Do I have to use it? I presently have a Creative Sound Blaster Audigy 2 Platinum that I can move over. What is going to sound better, the SB or the Onboard sound? If the SB will sound better, do I have to use the onboard sound attachment for the motherboard, or can I leave it disconnected all together?
Also, has anyone had any problems with this board? Can you recommend any others that are good, offer SLI on the 680i chipset that are close in price? Also, in regards to the dual networking... how can I take advantage of that? Will it be beneficial at all to me?
Thank you in advance!
Well, that is most of a model number, but not all of one. I am wondering if it is:
P5N32-SLI
P5N32-SLI Deluxe
P5N32-SLI SE Deluxe
P5N32-SLI Premium
P5N32-E SLI
P5N32-E SLI Plus
Maybe one I missed?
Aww shoot. It's the P5N32-E SLI. I tried editing the post, but I can't edit the subject of the post. :(
I have the P5N32 SLI Plus, and its basically a lite version of the Striker Extreme. The audio is ok, but Ill bet the SB would be better, so you just dont put the MB audio card in the slot and just put your SB in a PCI slot like you normally would.
Droc,
Do you happen to have any pictures of your rig anywhere? I'm curious to see the motherboard, as well as the back panel, without the audio port. Does anything look missing if you don't include the onboard audio? Like a missing panel, or does it look regular?
Bad picture quality, this I know. This is a p5n32-e sli plus with the supplied SupremeFX audio card. The audio card goes into a 1x pci slot so you can disconnect and you wouldnt even be able to tell it was supposed to be there.
Droc,
You realize that, like me, he has the P5N32-E SLI Plus, right? That is different (cheaper) than the P5N32-E SLI.
I am not familiar at all (besides the specs) with the P5N32-E SLI's audio. I like mine though, it works well with Vista.
Wait P5N32-E SLI Plus is cheaper than the P5N32-E SLI? Wow, I never would have expected that a PLUS model is cheaper than... well, without the plus! :)
Oh ok, so it's fitting in that port rather than a cable... that's what, PCI-X 1x? It has more options for sound channels, I'm just curious if it is better or worse than the SB Audigy 2 Platinum... I know that someone posted that the Audigy 2 sounds better, but it's tough to decide with only one review. :)
Btw, don't worry about the bad pics, you have no idea how much I appreciate you showing them to me!!!!! Thanks!
