ASUS P5N32-E Plus bluescreens and RAM issues
Wally
I recently built a 64 bit Vista-based machine, comprising two sticks of this OCZ "gold" RAM, an ASUS P5N32-E Plus, a Q6600 and a 512 8800GTS.
my memory's not perfect (badum-tish) as this was the week before Christmas, but as I recall, I installed vista using only one stick, and updated the BIOS to 0805 as i'd read of problems with the out-of-the-box configuration working with 4 gigs.
At some point I also installed Trackmania United, to which I initially attributed the issues: a bluescreen and IRQL_NOT_LESS_OR_EQUAL message upon using the optical drive. This happened about 50% of the time, and i'd also have problems booting if I had a disc in the drive, as it would bluescreen then, too.
I installed this hotfix: http://support.microsoft.com/kb/929777. I removed Trackmania and ran a starforce removal tool, thinking it might be starforce, but apparently United doesn't install any.
The situation has gradually worsened until I've reached this point; with the second 2Gb stick in the motherboard, I get 70% bluescreens when booting, disc in the drive or not. With only one stick I go mental at the stutteriness, but everything runs and boots happily.
With the second 2Gb stick in the motherboard, when it does let me get to vista, I get bluescreens on using the optical drive.
The confusing part is that i've just run memtest86+ on the single, working stick, and found no problems. I've run it on both, and there were no errors. I've just updated the BIOS to 0901, the latest version, and the problem persists.
The best part is that the week after I built mine my friend got jealous and ordered an identical computer, bar a smaller HDD/different case. I put it together for him in exactly the same manner and his is loving it. No issues at all.
Can anyone help me before I fly to wherever and set fire to OCZ/ASUS?
EDIT: More specific RAM info: OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK). Voltage upped to the recommended 2.1v, and timings set to the 5-5-5-18 stated. Neither the default or the altered settings differ as far as the crashes go.
Hi,
I sent you a PM but Im not sure if the info I sent will apply to your problem.
(I'm using 4x 1gb patriot epp ram and vista 32bit so you might get different results, but Iam succesfully running 4gb of ram)
Some suggestions if you have not already tired them.
(I would consider RMA'ing that motherboard if none of this stuff has helped)
There are 2 new BIOS updates for your MB but looks like they only address SB X-fi issues.
I had to up my ram voltage to 2.3v to get the 4x 1gb sticks to run stable (3x 1gb would run fine, but 4 would freeze up fairly soon after booting into Vista)
Also if I want to OC CPU past 3ghz and Ram past 1000mhz I have to set NB to 1.56v
Glad you got it fixed, because that rootkit can be hard to track down if you dont realize it's installed.
