asus p5n-SLI
TeleFragger
Ok so i bought a foxconn mobo.. cheap as anything from newegg.. $50.. well it powers on but cant get it to install vista, win7 or win home server...
different errors.. figured it is just a junky mobo..
so went to ebay and a guy had 10 asus p5n-sli mobos...
so i bought one..
they appear to be new oem.
came with mobo, case adapter, quick connect for case cables
plugged in all my parts that the other one had in it and the asus powers on... well the cpu fan spins.. no beeps or anything on screen.
did i get a bum mobo? i know not very descriptive.. this is what i have tried..
e4400 cpu, x3210 xeon cpu, pc2 5300 memory, pc2 6400 memory 2 different video cards (asus doesnt have onboard like the foxconn did)
i just cant get anything on the screen.... not sure what to try next...im trying to build a whs on a budget.. and the budget is creating tons of headaches...
What is the revision of the motherboard?
Since you left without giving the revision, I will fill in-
The E4400 is only supported on revision 2.00g and newer with 1401 bios and newer-
X3210 is not supported
sorry i was heading to bed....
so you say e4400 in rev 2.00g and x3210 not supported... however... i even put a p4 2.8 socket 775 in and that did not work either...
any other ideas?
ok look a look.. it is a 2.00g motherboard...
couldnt get video out of it with the e4400 or a p4 2.8
