Bizzare. They seem to have taken it down. It was up when I posted. I wonder why they took it down. I have the downloaded .zip file at home. I can upload it somewhere if you'd like.
How hard is it to install NB/SB fans or whatever on this motherboard? I'm looking at one in the forum.
hey guys, don't really have much time to read through all of these posts but i was wondering... how hot does the southbridge gets without a heatsink? i'm going to buy this board for a friend (e6600, 2gb Corsair, 7900gs) and i want to know if he would need a heatsink for it. also, how about the northbridge heatsink? does it work well or does it need replacement?
thanks![]()
Anyone tried the 0602 bios?
The trick I found to get four sticks of ram working in this board is to set your ram speed to 667 or lower and set your first 4 timings manually. Mine is set to 5-5-5-15 @ 667mhz and the rest is auto.
After working on mine forever, the trick seems to be to set it to anything but 800mhz. I got mine working fine anything above 820mhz. It's around 900mhz right now. The second I put it back to 800mhz, it crashes non stop.
P5N-E SLI only running video card at x1 not x16. Help!
Right now everything in the bios is set to standard settings. I'm not trying to do any over clocking. I discovered my card was only running at x1 because I was getting horrible scores in 3dmark in both xp and vista.
How would I check to see if the card is getting enough voltage?
This doesn't seem like more of a mobo issue?
I just bought this NB heatsink. Anyone have any experience with it?
Anyone try the new C2D 1333mhz on this mobo yet?
I'm thinking of upgrading but want to see if anyone got a new bios or have gotten the new chip to work no this mobo.
I don't see how it would be a problem, I run my 6400 on a 1600MHz bus with no issues. You can unlink the RAM speed from the FSB and run whatever memory you want as well.
Mine stopped allowing me to update BIOS from a flash drive. It detects it but after it reads the file it says its not compatible. Weird that in the top right window it recognizes the file as being for the right board.![]()
