z0mgitsryan
- Oct 13, 2008
I just tried to build my new PC last night since all the parts I ordered online finally came. But right when I was trying to load Vista 64bit It crashes and gives me BSOD (IRQ_NOT_LESS_OR_EQUAL)! I kinda did some research and I found out that It might be the memory or the CPU overheating.. I kept checking my temps on the BIOS and I am pretty far from overheating, also I have a Artic Cooling Freezer 7 PRO. Then I tried removing 1 of the memory sticks and re installed Vista 64bit and that worked out pretty well. Right after I loaded the OS, I download and updated the newest version of BIOS and that worked out pretty well also. After that, I tried installing the other memory stick again.. And there you go, another BSOD. So, I'm guessing its the memory thats bad? Or am I doing something wrong? I also set the factory memory settings and voltage on the BIOS. I just really hope its not the mobo since I dont want to take out everything all over again..
Any advice from you guys would be great!
Thanks..
Thanks..
