Well i'm speaking on behalf of my friend who's having insane pc performance problems and i'm his only meens of helping him out so I figured i'd goto the best =)
The journey started back when he purchased his brand new E6600 processor with 2 gigs of G.Skill DDR2 800 ram and the Asus P5L-MX MicroATX Motherboard a day or two ago. He recently also bought a brand new 250gb SATA 3.0GB/s WD Hard drive to top it all off to replace his broken raptor hard drive.
Now, the formatting, windows installation and drivers installation went absolutely smoothly but somthing was going majorly wrong when he began trying to play ANY games (he mainly plays Counter-Strike Source and some Call of Duty 2). He would only get from 20-50fps in both games which are two seperate engines.
He's currently using a 7900GTX PCI-e video card and he's used this card even on his old AMD 64 4200+ rig which gave him insane fps as expected, WAY above 20-50fps as he's recieving now on his current Conroe rig. He's even tried his spare Geforce 6600GT video card and still gets the same exact low performance as the 7900GTX.
I've had him try reinstalling his intel chipset drivers... disabling any onboard video... installing and uninstalling early releases and latest releases of the Nvidia drivers for his video card, even got him to flash his bios to the latest version and STILL no luck.
Now to me, it sounds as if somthing isn't getting enough power of some sort. The PSU he's using which is a cracked out 550Watt Antec with all those fancy schmancy customizable connectors works absolutely fine being that it was just transfered to and from his old AMD rig to the current one he's on now so I automatically voided out the fact that the PSU could be sending out lesser power than needed.
The ONLY thing that I havnt asked him is if he has his 12v power connector plugged into his motherboard. (usually the top left corner of any motherboard with that "square/box" looking power connector) That's pretty much the only thing I can come up with but i'm quite certain he has it plugged in because if im not mistakened... the rig wouldn't boot up without the additional 12v power connector.
Anyone have any ideas on what's going on with this situation... it's absolutely weird. Oh and to top it all off, everything in windows and so forth works perfectly fine and snappy as expected so all of his problems seem to be graphic related.
*EDIT* The 12v IS infact connected or it wouldn't of booted at all so I guess that's out of the question... still need help as to what's going wrong =/
*EDIT 2*
There's obviously a serious issue here lol.
*EDIT 3*
Well from the looks of it we both overlooked the fact that the multiplyer was only at 6x and it needs to be at 9. I'm assuming that this mobo boots at 6x rather than the expected 9 so we'll see if that fixes anything.
*EDIT 4*
We went into the bios and there isn't ANY cpu multiplyer feature
*EDIT 2*
*EDIT 3*
*EDIT 4*
