Asus P5K-V...
kimmief
I have this board and it supports crossfire. I've not used any ati cards, but if I was to go crossfire, what should I get. I am currently running the 8800... Thanks!
What is your E6320 running at? If it isn't overclocked, then crossfire anything won't be worthwhile.
All things aside, your current PSU is going to limit your options.
4850 CF is going to be the best you can do at the moment, although I don't know how good the Trios are, if they can even handle it.
Although the bigger question is... Why do you want to go CrossFire?
What games? Resolution?
I've had it up to 3.0Ghz, but right now it's just stock 1.86Ghz
Well put it back to 3 GHz!
You'll see a huge improvement in your games just by raising your CPU clocks.
