Asus P5K PRO Help Needed...
CanonicalAbstract
Special Attention Whore
I just put together my new parts tonight, and am running an ASUS P5K-Pro mobo. My HDs are on SATA1 and SATA3 (Primary / Slave respectively), and my DVD burner is on the Primary IDE, set as a Slave, plugged into the middle port on the IDE cable, and everything.
What I am trying to do is get my DVD to boot up my Windows VIsta disk. I was able to do so in the past before I upgraded. But now it seems like the DVD drive does not want to even boot up.
I double/triple/quadruple checked all my plugs, settings, everything. I am at a loss! I am on hour #5 with this machine, and I just want to be able to get this thing going tonight!
Thanks.
As of now, I'm resolving to purchasing a SATA DVD burner, but if anyone has any advice on this, that would be greatly appreciated.
First off why do you have the IDE DVD Burner as slave? There's no sense in that if it is the only thing on the IDE channel.
Does the LED light up on the DVD drive? Do you at least get a "hit any key to boot from CD/DVD" prompt? Do you have another system to test the DVD burner in?
You may want to check Bios as well to make sure that the DVD drive is detected, and that the priority for your boot devices has the DVD drive before the hard drive that you are going to install the OS on.
If I recall, the IDE on the motherboard is primary, and the DVD drive set as a master, it actually won't work. Correct me if I'm wrong though, but usually, a HD is set as the master on a primary IDE channel.
The DVD does light up. It acts as though it reads the DVD/CD, but I do not get a prompt to press any key to boot from DVD or CD. It just goes straight to the HD.
I did check BIOS, and I had the CD-ROM set up to be the primary boot device (I always ensure of it). However, it was recognizing my DVD drive as an ATAPI CD-ROM, and not reading anything. Even in Vista (somehow, the install files from when I tried to install before the upgrades) the DVD drive was non existant.
I actually went and bought a new DVD burner (HP DVD writer 1070), and BIOS recognizes it right away (Its SATA, and plugged into a secondary SATA port on the mobo), I reformatted and reinstalled Vista, my machine is now rocking something fierce.
