Hey guys,
Im having XP-booting/blue-screen-of-death issues with my new build. My reason for putting htis in the MB category is I think it may be a BIOS issue.
Just today I finished buying parts for my system:
ASUS P5K / EPU Motherboard
INtel Core2Duo E8400
2G Generic RAM
80G Seagate Barracuda (unformatted, from old system)
430W PSU
I built it this afternoon and the hardware side of things seems to be fine, the system runs and is perfectly stable while looking at the BIOS and stuff. The issue is that when, normally, you would get the XP logo and some loading bars, instead i get the dreaded blue-screen.
The HDD is using the IDE slot, I'm wondering if this could cause an issue. The slot is on the board so using it instead of SATA should still work fine yeah? The HDD vibrates and hums, so it is doing SOMEthing but nothing productive it seems.
Things done to try and resolve the issue:
Test HDD on another system - works fine and boots XP.
Tested IDE cable in different machine, works fine.
Triple checked all hardware connections.
Triple checked that HDD is the master drive. (for debugging purposes its the only drive in right now)
I am totally stumped and I could really use some help if anybody knows anything I can try, in the BIOS or otherwise.
Thanks alot
2G Generic RAM
430W PSU
Thanks alot
