eva2000
- Apr 14, 2002
System
Swapped over to 2x1GB Crucial Ballistix 8500 dual channel kit.
Super Pi v1.50 32M
7x499FSB = 13m 28.313s
7x500FSB = 13m 37.844s
Everest Ultimate (MB/s)
7x499FSB vs 7x500FSB
Memory Read: 10809 vs 9964
Memory Write: 9096 vs 9115
Memory Copy: 9615 vs 9157
Memory Latency: 46.0ns vs 51.8ns
Settings Used
Strap change does exist it seems at 500FSB changes to lower memory bandwidth performance compared with 499FSB.
- Q6600 QUPT B3 ES
- Corsair Nautilus 500 3/8" ID
- Asus P5K Deluxe 0311 bios
- 128MB Gainward FX5200 PCI
- 2x1GB Crucial PC2-8500 Ballistix dual channel kit
- 74GB WD Raptor 8MB on SATA 1 port
- Pioneer DVR-08 Burner
- Sony FDD
- 1KW PCP&C SLI psu
- WinXP Pro SP2
Q6600 B3 - Asus P5K Deluxe Strap Change
- It seems for my Q6600 B3 max FSB depends on how well memory modules can handle certain settings. Why ? Because my Q6600 B3 can hit 495-500FSB alot easier with this memory than other memory I've tested. Other memory hit max FSB around 490FSB.
- Also I might have found a possible strap change for Asus P5K Deluxe (maybe only noticeable with very very tight subtimings ? ) @500FSB. At 7x500FSB, memtest86+ v1.70 reported 6216MB/s bandwidth. At 7x499FSB, memtest86+ v1.70 reported 6505MB/s bandwidth!.
Super Pi v1.50 32M
Settings Used
JumperFree Configuration Settings
AI Overclocking: Manual
CPU Ratio Control: Manual
- Ratio CMOS Setting: 7
FSB Frequency: 499 & 500
PCI-E Frequency: 100
DRAM Frequency: DDR2-1248 & DDR2-1250
DRAM Command Rate: 2T
DRAM Timing Control: Manual
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 5
RAS# Activate to Precharge: 9
TWR: 3
TRFC: 30
TWTR: 3
TRRD: 3
TRTP: 8
DRAM Static Read Control: AUTO
Transaction Booster: AUTO
Boost Level: N/A
Clock Over-Charging Mode: AUTO
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Voltage: 1.5v
CPU Voltage Reference: x0.63
CPU Voltage Damper: Enabled
CPU PLL Voltage: 1.50
DRAM Voltage: 2.40
FSB Termination Voltage: 1.40
North Bridge Voltage: 1.70
North Bridge Voltage Reference: AUTO
South Bridge Voltage: 1.20
Advance CPU Settings
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
PECI: Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support: Disabled (need to enable it to detect USB flash drives)
Q6600 B3
7x499FSB
vs
7x500FSB
7x499FSB
vs
7x500FSB
