Asus P5K + 128x64 = ?
Nemik8800
Well I just got all my parts for my computer and as I was reading through the manual of my Asus P5K Motherboard it said "This motherboard does not support memory modules made up of 128 mb chips." The ram I orderd is 128x64:
http://www.newegg.com/Product/Product.asp?Item=N82E16820146565
This is the mobo:
http://www.newegg.com/Product/Product.asp?Item=N82E16813131180
Its not on the QVL but similiar versions of the ram is. With model numbers that consist of "12864". Should I even bother or just send it back and find something else?
I just build a system with that same motherboard but I used the Kingston 2 gig kit and have not had a problem it is picky they say about ram so i would look on the Newegg's site in the reviews and see if there are any mention to using that ram on the P5K board mine is running a 6750 C2D with the Zalman 9700 HSF stock it is blazing fast compared to my other P-D 3.74 gig 945 well good luck with your build.
Thanks alot man. Im just gonna look at Neweggs return policy and see if they allow me to return opened ram. If not I got some more research to do before I try. I looked on their site and I cant find the QVL for my board so they need to make it retard friendly me thinks.
