Asus P5E-VM HDMI + E5200 = FAIL?
krick
I've been running my Asus P5E-VM HDMI over 6 months with an E7300 2.66GHz (10 x 266) overclocked to 3.4GHz (8.5 x 400). All I did was drop the multiplier to 8 (from 10) and bump the FSB to 400 (from 266). I didn't change voltages or anything, I just left everything on "AUTO". See... http://www.hardforum.com/showthread.php?p=1033410017
Now, I've gotten my hands on a cheap E5200 2.5GHz (12.5 x 200) and I wanted to try a little overclocking to see what it could do on this board. For some reason, I can't seem to get the FSB anywhere near 400, even when the multiplier is dropped all the way down to 6. The best I can do is about 360MHz.
I have a Thermalright HR-01 Plus so I know that cooling isn't the problem. I've even tried bumping the CPU voltage up to 1.3625V so I know that's not the problem either.
I'm stumped. I know the board can do 400 FSB. I've heard of people getting MUCH higher than that, in fact. Is there something I'm missing?
What strap are you using?
I'm using "AUTO". I'm not sure what I should be using.
I've been playing around with overclocking it more and the strange thing is that as long as I keep the FSB at 333, I can jack up the multipler quite a bit. I've managed to get it into windows at 11.5 x 333 (3.83GHz) and I'm prime95 torture testing it now.
I'd much rather run 9.5 x 400 if I could get that to work since it's essentially the same final clock speed but with a better memory ratio.
Don't have it anymore but I used an E5200 on the board for quite a while. Though now that you mention it I did run 9x333 but never had any issue at all with it.
the e5200 has a pretty low FSB wall. 360 is right at the limit irc. thats kinda good in a way because you can get pretty high speeds because of its high multi. you wouldnt be putting too much load on your mobo with a high FSB.
Set it to 333 because you are anyway in that range, and see if that makes any difference. It might not, though: as said before, The E5200 was not made for a high FSB. 333:400 FSB:RAM ratio isn't too shabby anyway.
