Try monitoring the temperature with Real Temp.
btw anyone else with a P5E-VM HDMI using a q6700 can tell me what they do to oc theyre cpu ?? and is it best for a beginner to leave core volt at auto or set it on manually caus of the vdroop (havent done the vdroop mod yet) and with bios 0503 is the vdroop becoming less or still just as bad as before ??
none to be honestwell the only one that made it to the vista 64 OS with everything else on auto or on how they supoosed to be except for pcie (yup im definatly noob!!)
was at 322x10 it crashed after 10-15 sec of prime, and btw apparently it doesnt except any 0 !!?? in my fsb so couldnt do a 300fsb x10 one and i just wanted to be around 3.2 ghz so that why i put in 322 but i will look more into it tonight or wednesday but any suggestion ?? caus that will be highly appreciated i know best way to learn sumthign is to do it urself but sum help would be really nice..
ah k i will try that as soon as im home and let u knowthnx for the info
btw what are your temps idle and max when running prime ?
im using Artic Silver 7 or sumthing like that.. and yup ddr2-800 ram
Ubuntu supports the Lan on this board for me just fine.
Are you having any issue w/ onboard video? Mine seems to hang when GDM loads...sometimes. And I cannot get suspend or audio over HDMI working![]()
Hi trent,
I'm also having this and I'm still waiting for an answer, it is like this since the board came out. If you try 5-4-4-12 you should read 5-4-4-12 but 4-4-4-12 seems impossible to get because it always read 3-4-4-12, weird!
I see that BIOS 0505 is now on the Asus site. Anyone used it yet? Curious what changes there are since 0503... I'll give it a shot tonight.
Edit: They just took it down. 505 was up there a few minutes ago with a 4/28 date, but now it's just 503 again. False alarm, but maybe a new one is soon to arrive.
505 is back. At least on the global site ...
I should hopefully have my hands on a Q9300 Monday. My current Q6600 is at 3.3 Ghz, but I also have 8 gigs of RAM.
I have a Q9300 ( terrible for OC'ing ... I know ) and I was hoping to get it to 3.0GHz. Has anybody here used a Q9300 ? What did they get it to do ? What were the settings ?
I have a Q9300 now, and can get to 3.0GHz w/ 1.08V (1.1V set on BIOS). Just leave everything stock basically. I would double check your memory settings, especially voltage (maybe set it to 2.0V for now).
Interesting. If I leave everything else on AUTO, it isn't stable. If I raise VCORE to 1.2650V then it seems stable in Memtest and also in ORTHOS / Gromacs CPU Stress
But as soon as I use the Blend or any other test involving RAM, it will crash. I think either my PSU (LC-6550) is crap or then it is something to do with FSB settings (FSB needs more voltage ?)
Memory is G Skill DDR1066 at 5-5-5-15 and I am using it at DDR2-800 speeds. Voltage at DDR2-800 is 1.8v but I am feeding it 2.0v anyways
Strange....all my VTT, FSB, MCH, etc. settings are on the lowest voltage possible (I undervolt only since this is a HTPC). Not sure the specs on your PSU, but something is definitely wrong with your setup. The P5E-VHM HDMI can handle up to 400MHz FSB easily. It's around 450+ MHz where you need to start pumping more voltage.
BTW> What does CPUZ report your VCore voltage as? Maybe you got some big time Vdroop going on...
Core Temp reports vid as 1.050V. Will try to get CPU-Z reporting on VCORE. But is this the infamous VDroop problem ?
Should CPU Voltage Damper be AUTO or ENABLED/DISABLED ? And what is the CPU Voltage Reference ?
I am at work right now, but in desperation last night, I raised CPU voltage to 1.4V -yikes ! And the machine is now stable. So after work, I am going to get all other voltages to AUTO or default values and try raising only the CPU voltage. What I noticed in the ASUS health monitor section was that VCORE was between 1.240v and 1.248v. Raising VCORE in the BIOS has NO effect unless I pushed it to 1.4V. And then the ASUS Health Monitor reported 1.38v on VCORE. Core Temp reports vid as 1.050V. Will try to get CPU-Z reporting on VCORE. But is this the infamous VDroop problem ?
Can "Asus AI Suite" be trusted for reporting the correct Ram voltage with this board?
I got my 2x1GB PC-6400 Ballistix Tracer running at 500Mhz 5-5-5-15 @ 1.88v (in the Bios). But when I check AI Suite it says that my Ram voltage is 2.0v. So which is it???
When I was trying 400MHz 4-4-4-12 I had to go up to 2.0v in the Bios, at that time AI Suite was reporting something around 2.35v !!!
No one has AI Suite installed !?!![]()
As Rhialto noted, only trust what CPU-Z reports as the VCORE and NEVER just blindly raise your VCORE, unless you don't mind frying your CPU. Lookl ike you have a massive case of VDroop. I would do the VDroop mod then, since you are bent on overclocking. 3.0GHz overclock is pretty easy on 45nm (I've done it on 2 Yorkfields and 1 Wolfdale already), without much voltage and all stock mobo settings. COuld you also tell me what your temps are reading via Real Temp? Just want to make sure you don't have a HSF issue either.
