MurderCityDevil
- Dec 6, 2007
exactly what the title says. What would you recommend? it's basically just a 30 dollar difference along with an led poster and more bios options. I want to hear your thoughts.
"1) All solid caps, the P5E also has good caps."
If the P5E is basically the same board doesn't it have the same solid caps?
I thought my P5E had all red caps.. I could be wrong though. This Xbit Labs review one does, anyway:
http://www.xbitlabs.com/misc/picture/?src=/images/mainboards/asus-p5e/board-2.jpg&1=1
Are the red caps better then?
