ASUS P5B Wi-Fi Problem
Late yesterday after installing a new hard drive when I booted up I started getting BIOS beep codes that my video had failed. I re-sat the video card several times but still got that beep code. I then took the video card from the computer having issues and placed it in my other system and the video card works fine there. So is my motherboard dead (ASUS P5B Wi-Fi) or is there a way to reset it? I tired resetting the CMOS but no luck. I've looked through the manual and can't find a thing. I also posted this quesiton to the ASUS forums but no one has responed yet. Thanks!
Does your videocard require additional power connections? Have you checked your power supply? If your power supply is good, I would say your Asus P5B is bad.
