asus P5B vs. P5LD2 and IDE issues
rob75
Hi all,
I'm goin' to assemble a new PC, having CONROE E6600,
and suggested MoBo is of course ASUS P5B (965 chipset)
Now, I woul like to use my old HDD's (both ATA133), and my CD drives (both Ide)
The proble is that P5B has only 1 Ide connector, the other are SATA.
( someone says that P5B has an external chip able to allow to automatically handle IDE drives. Is that true? )
P5LD2 MoBo instead has 2 Ide connector, so no problem (but maybe it's not a good choice to have a 945 chipset for a Core2Duo E6600...)
Based on your experience, should I buy P5B + some PATA-to-SATA adapter,
or instead it's a better choice to get P5LD2?
Any suggestion is welcome
Thanks
Rob
We are running some P5LD2 and P5B boards here and while i have never put a C2D chip on a P5LD2, we have had excellent luck with them. The only thing i would be weary of is the BIOS version on the LD2 because we had to upgrade them even to support the 631. If your board doesnt have a new enough bios to recognize your chip you cant update the bios until you have a chip it does recognize or you can call asus support and have them mail you one (for a small charge).
But i say the LD2 should be a good choice IMO.
