ASUS P5B USB problems...
Dethred
Ok, so I installed windows (which would still load up fine after switching motherboards) I installed the chipset drivers.
After restarting the USB devices do not work anymore. What the heck is wrong with these Core 2 Duo boards? Any ideas on what could cause this? The board detects the mouse before windows starts up because the Laser on it is glowing red.
USB ports supply voltage to their connected components regardless of whether there's a real device attached or not.
It's how people can get USB lights and fans to work :).
As for your problem, open up device manager in windows (if you can... try using a PS2 mouse, or a converter) and see if there are any yellow icons next to your USB controller.
If there are, you might be able to uninstall the device driver, then restart and allow windows to 'find' the correct drivers...
ok I think I got that fixed, now I am stuck with another problem... CPU-z is detecting my C2D as a Pentium M and saying its running at 2.67v :eek:
