Hello, all.
I finally decided to give overclocking a try, and boy is this stuff weird.
First of all:
Asus P5B
E6600
2x2GB DDR 800
I took the Bus speed up to 329. THis should result in about 3.0ghz. Now, when I go into CPU-Z to check on that, it says my multiplier is now 6, instead of 9. If I stare at it for a little bit, it says the multiplier is 9. Then it goes back to 6....And then 9 for a sec...and then 6...
Is this normal? Am I actually getting the speeds I want? Or is something going wrong here?
First of all:
Asus P5B
E6600
2x2GB DDR 800
