Asus P5B MCH Voltage (Auto?)
macrospect
I am overclocking my E6600 and am satisified with a 3304mhz (8X413) overclock. So far I haven't run a 24 hour Orthos on it but it has been stable for a quick 4 hour test. Voltage wise I am running at 1.3625 but the actual voltages I measured are 1.346idle and 1.324 load. Should I be worried about setting a voltage for my NB chipset or should I just leave it at auto. The only other voltage I set was for the RAM (I changed it from auto to 2.00V to compensate for the 13mhz overclock). I am trying to achieve the lowest possible power consumption and still be stable. This way I am not dumping tons of wasted heat into my room.
Thanks.
PS. Happy new year everyone!
Don't leave it auto... Voltages for me (when auto at 500mhz FSB) were in the 1.4 range... I was fully stable in the 1.3 range...
Really, Orthos wont tell me this though, correct? I decided to run Orthos last night (still running as of now) to make double sure I am stable with my mild overclock of 3302mhz. The reason I don't go higher is because of wasted heat. My room is too small to be outputting that much heat (especially when it begins to get warmer outside).
Other than that I just passed the 12-hour mark for Orthos. It has a priority of 9 and is doing small-tft's. I am keeping my fingers crossed that everything stays stable.
After Orthos is finished I will run memtest 86 for 8 hours or so to make sure that my NB and RAM is stable.
PS. When I set auto for the VCore voltage (on the CPU) it was pumping like 1.5V into it! I think auto actruall overestimates the amount of voltage required for the chip to run.
Looks like I am good to go. 21 hours Orthos stable at 3302 (413X8). No signs of instability at this point.
Thanks for the above replies/recommendations!
