Asus P5B Deluxe - No Boot, help!
spressa112
Here's my system:
Asus P5B-Deluxe vers. 1.03g
Wintec 2x1gb (ddr800)
Geforce 8800gts
e6600
corsair hx520w
my pc was working, went out for my bday last night
came home and pc was turned off....
i had it at 3.0 previously but then i bumped it back down to 2.4 yesterday morning to get my room a lil colder
i try to turn it on and there's no boot
this is what it does:
i turn the pc on
monitor detects signal but then goes back to detecting no signal
then pc turns off by itself
(this is all within 7 seconds)
the pc turns back on itself
does the same monitor detection, detects and then doesn't detect
but stays on this time
no boot, no bios messages nothing
i have done this so far:
a:
1)removed all power
2) took out cmos battery and cleared cmos jumper
3) put it all back in
4) still no boot and does the same thing
b:
1) removed all power
2) took out all ram
3) turned on to see if i get any beeps for no ram
4) no beeps at all
5) but does the same on and off thing again
6) put ram back in
7) does the same thing again
c:
1) remove all power
2) clear cmos
3) changed single stick of ram each dimm
4) each time, does the same thing
d:
1)unplugged everything from pc
2) only mobo, cpu, vid card, and ram
3) still no boot
what do you think is the issue
i had latest bios installed and everything was running fine til i came back home from last night
so your screen is now black.. saying something about video RGB.. ??
I had this problem in the past.. it was due to the graphics card.. reseated.. worked after that.. Since i leave the side panel open i always tend to kick it. :p .. welll.. USED TO
it's the motherboard, just took everything out.....
i put everything piece by piece into my friends pc......
cpu, vid card, ram, power supply. everything works.....2nd time i've returned this motherboard in 1 weeks....
isolated it down to motherboard....
man, i'm so fucking pissed.....seriously........just outta no where, fucking......
I feel your pain. I have the same board first one would not even power up. I sent it in, had it fixed and returned. Put everything back in, I have system power, but no post. Then like yours the power shuts off and comes back on all by itself, and still no post. I run through every check that you did, and like you, still sending the board back.
I wish I would have checked a few forums about issues with this board rather than just read about tech specs and reviews.
Remove the BIOS battery and PSU power cord overnight.
It should boot in the morning.
This is ASUS's way of resetting the BIOS, and it's limited to the P5 series only. It's actually a fairly good way of doing it IMO.
This has happened to me countless times... The official "wait" time is 10 minutes, but that doesn't always work IMO.
i left it out for 3 hours, no power and now cmos battery for 3 hours.....
no boot at all, always give me red leds at the bottom....
no boot codes, no nothing.......
i put everything in my friends pc, works fine.....
such a fucking hassle.....it's a good board, don't get me wrong, some minor things that annoy me like the jmicron and the hell of a long time to get the hardware monitor to show....
imma just return and get a new one, directron is only a 25 minute drive away...
got new motherboard today....
put it all in, now it doesn't have the double boot issue but turns on and stays on but doesn't boot, tried cheap stick of ram....doesn't work....w..t....f.?
last post and close thread....
tore everything apart one more time, if everything wasn't gonna work, it was all getting returned..........
you know what was wrong with the new mobo? 1 pin in the socket was messed up on the new board........bent it back up with a needle and the computer is running straight again....
3.61 @ 42c....ftw.....thanks everyone
