Asus P5AD2-Deluxe Boot Order problems
mikeblas
[H]ard|DCer of the Month - May 2006
I'm getting frustrated with my ASUS P5AD2-Deluxe. I can't seem to make the BIOS boot order work the way I'd like it to.
I have seaveral drives:
A: Floppy
C: 160 gig HDS722516VLAT20 (Parallel IDE)
D: 40 gig ST340016A (Parallel IDE)
E: 2 x 300 gig SATA, in RAID 0 array (SATA)
F: CRW-5232AS CD ROM R/W
G: SOHW-1633S DVD R/W
I boot from the C Drive, normally. The D: drive is just a drive from an old machine, and the E: drive is for mostly scratch storage. F: and G: are removable optical drives.
That much is fine. Where I run into a problem is trying to boot from CD. No matter how I set the BIOS, it doesn't work. If I use F8 to get to the BBS popup and explcitly select my desired boot drive, it doesn't work. The machine does show a message saying "A bootable CD ROM Was detected", but it doesn't boot form the media.
If I manipulate the BIOS settings so that the machine boots from the CD, it will no longer boot from the C: drive once I remove the CD.
The BIOS is quite confusing; I've got two different places to set the boot drive. Under the "Boot" menu, there's "Boot Device Priority" and "Hard Disk Drives".
"Hard Disk Drives" lets me make a list of my drives, including whatever drive might have a bootable disk in it. Thing is, a drive will only show on this priority list in the BIOS if it had a bootable disk in it at the moment the machine was started.
"Boot Device Priority" only shows the floppy drive and the #1 drive from the "Hard Disk Drives" page.
How do I set this BIOS to get me what I want?
This is finally buggin' me enough that I'm going to get under the desk and figure out if connecting the drives differently (eg, to different ports) ends up fixing it. But I'd love to have any hints from those who've used this motherboard (or this particular flavor of AMI BIOS before.
