Where to start...
I had to replace a motherboard from a hp pavillion and I am using this as the replacement: ASUS P4V8X-MX Socket 478 VIA P4M800 Micro ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16813131573
Got it all hooked up to find out one minor problem. HP's case comes with a brick connector that differs from the new mobo hook up for power switch / reset / hd lights.
no big deal I just do the little trick of touch the two power pins trick and it turns on.
All that happens is the fans spin at maximum speed as they usually do before the bios kicks in, but thats it. It goes no further.
I have popped out the bios battery to try and reset it, i've remounted the CPU, ram.. blah blah blah but I get no where.
Looking for some suggestions / help on this one.
