When I install 2x512 sticks of PC3200 (400MHz) memory on the motherboard I get intermittent crashes in games, applications. Prime95 gives me a lot of memory errors, as I would expect from the former behavior. I tried running the memory at lower frequencies, but got the same result. I tried with both Kingston Value Ram and TwinMos Ram (probably value, don't remember).
However, when running 2x512MB PC2700 memory at 320 MHz, I get no errors at all. The computer won't boot with the memory set to 400 MHz (obviously due to the memory).
The rest of the computer is a P4 2.8HT in a 350W case, couple of hard drives, cd roms and a Radeon 9800 Pro. Everything was set to stock speeds at the time of testing (no oc at all).
Anyone have any ideas on what the problem might be ?
