ASUS P4P800-E and ECC RAM
andrewhaji
Does anybody know if the ASUS P4P800-E works with ECC RAM? I just had a stick die on me recently and it nearly corrupted my entire drive...I'd like to get some ECC RAM if possible. Does anyone know if it works?
Thanks!
Umm check in your BIOS.. you should see a ECC setting.. Almost every MB supports ECC as an option. (some high end boards it is a requirement)
==>Lazn
Thanks!
That board uses the 865pe chipset, which does NOT support ECC memory. ECC memory may work in it, but it won't take advantage of the ECC part.
The 875p chipset boards support ECC, such as the Asus P4C800.
Thanks, I was too lazy to look it up.
I really should have been too lazy to post anything, (as bad info is worse than no info) but you know how it is when you get into a posting mode... But what I don't get is why he was too lazy to google it, or to look in his manual, or his BIOS..
==>Lazn
