Asus P4P800 Deluxe
rbf351
wondering if anyone else has any issues with this board?
i tried to enable USB 2.0 in full-speed and high-speed
when i use the setting that is over 12 MBPS the bios crawls
i tried updating the bios, that didn't work. not sure what else i can do to correct this.
I've got the P4P800E-Deluxe and never had that issue. What BIOS revision are you running?
figured out the issue, it was the scanner and printer plugged into a hub, not sure why it was doing that, but that was the reason
