Asus p4p800 beep codes??
scrapz
I've been looking for these beep codes all day but no luck, I have till wednesday to figure this out. Lan needs to be up by then and about 10 of my comps arent working because of this. the beep code : 2short-6short
Phoenix BIOS Beep CodesPhoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps. Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
Award BIOS Beep CodesAward BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
AMI (American Megatrends International) BIOS Beep Codes.AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
http://www.amptron.com/html/bios.beepcodes.html
