ASUS P4C800 Deluxe problem...
nsanity
I have the above motherboard with a 3.2 Ghz P4 Northwood (w/ HT).
Some stuff from CPU-ID:
Brand ID: 9
Voltage: 1.616v
Family: F
Model: 2
Stepping: 9
Rev: D1
FSB: 199.9
Bus Speed: 799.6
BIOS Version: 1019.002
RAM:
Channels: Dual
1 GB (2 sticks) DDR-SDRAM
Freq: 133.3 Mhz
FSB:DRAM: 3:2
cas lat. 2.0 clocks
RAS to CAS: 3 clocks
RAS precharge: 3 clocks
Cycle time: 6 clocks
1 stick is kingston, 1 stick is Nanya (I know, I know)
Video Card: Radeon 9600 XT @ 8x
My problem is this:
My system turns itself off randomly. Not a reboot.. just powers itself off. I was trying to watch an AVI from an external USB HDD and it shut itself off twice in 15 minutes. It did it again after I copied the AVI to my desktop and started watching it from there.
It has also rebooted while copying large files over the network, so I stopped using the onboard GigE and put an Intel Pro 100 NIC in there. It didn't reboot after copying the file this time, but it still rebooted often. I have tried re-installing a couple of times as well.
Sometimes I can use it for two days and it won't cut off. I've done 3d rendering/video conversion on this thing and it chugs right along without a problem. Then there are days like today when it cuts off a will 3 times in half an hour or so. I keep thinking it's got to be a windows problem because I had Ubuntu installed on this thing and it never cut itself off once. I don't even have to be using it for it to cut off.
Anyone have some ideas to try? Hit me with what you got because I'm running out of things to try. Any help is great appreciated. Thanks!
Sounds like a power supply issue, or maybe an actual electrical problem in the house. Try a different outlet, a cheap UPS, or swapping the power supply out.
Also, you may have a short. Check your case for a loose screw behind the motherboard or maybe it's not affixed properly. I had that board and shorted it a few times by not having stuff screwed in all the way/screw loose (funnny). I doubt that would be it, because usually a short prevents a POST.
Definately not a short... the case is acryllic. I'll try another PS, but this thing is brand new CoolMax 400 Watt PS. I've been running it on "High" to see if it makes a difference... none yet.
