ASUS P2B-D Problem
Thorbjorn
Had this thing for over five years now with no problems, rock solid!
The old configuration was:
single CPU P2-350
512MB's
MX-440
SB Live! OEM
3COM 3c905b NIC
10 & 12 GB WD HD's
52X max CD rom
HP 8200i CD burner
combo floppy drive
I came across two P2-450's and a gig of ram so I was going to make it a file/game server. Finally got around to installing it all, but the thing would not boot. After unplugging a HD, the CD burner, and the floppy drive, it finally POST'd and worked fine and I was able to install WinXP Pro.
I was thinking, "I need a beefier power supply" so bought an Antec True 430W and installed it. It still would not POST. Even with all that stuff unplugged, it sometimes will not POST. I tested the new RAM and it is good. I tried using the old RAM, same problems. Using a single CPU, it seems to always work fine.
Has anyone encountered this? Got any suggestions, hints or whatever? I'd really like to put the cover back on and get on with gaming.
Thanks!!
Does that board need a second VRM module installed? Are you sure both CPU's are good? Are they a matched set? If the CPU's are too many steppings apart they will sometimes not work together.
make sure your connectors are clean also. any oxidation or residue can cause strange effects also.
Sir-Fragalot
A second VRM module? Well, there's nowhere to plug anything in so I'm "guessing" no... <shrug> and the manual doesn't say anything about it. The CPU's are as closely matched as I can get them. All the numbers are identicle except one is made in one country and the other in another country. Besides, after fooling around with the thing for a while, it does eventually boot up and work flawlessly. As long as I never power it off after a successful boot, it always works like a charm.
nst6563
I haven't done any component level electronics work in some time... is it a burnishing tool that I want to ask for at Radio Shack to clean the contacts?? If not, what's the best tool for the job?
try alcohol or acetone with a something small. if you really want to get them clean and shiny, a fine grade sandpaper will work too...just be sure not to get any of the metal "dust" on anything else.
post your CPU's steppings and other info. I have a PIII 450 I'm not using any more...I could part for some cash. I'm at work now...so I don't know my steppings...
