ASUS nForce 4 Native Command Queuing
mesar
I have an ASUS nForce 4 SLI Deluxe motherboard. Having problems with freezing right now. I even put on a previous image that worked before, and it freezes with that. I have done diagnostics to the hard drive using windows tools, norton, and system suite, have not found anything wrong with the drive. I found that the file system has errors. I remembered that ASUS nForce 4 motherboards would corrupt with native command queuing. I have a 300 gig SATA with native command queuing, seagate. How would I turn this off, to test to see if this could be the problem?
any help would be greatly appreciated, thank you
Is it on the chipset controller or the Silicon Image controller?
its not raided, and I have the hard drive on SATA1 on the motherboard. Also, I do have another SATA on SATA2 on the motherboard, buts its not ncq. I have another hard drive that is IDE, and have that set as master.
Run 1002 bios with out ide drivers installed or run 1007.002 bios with 6.39 or newer installed.
Currently I'm running 1002 with out ide drivers.
If you still have problems, play with the jumpers (if any) on your harddrive... Remove jumper completely or put on master setting.
If your still having problems, doubt it would be the harddrive.
NCQ can be disabled in the Device manager in Windows. I think in the driver properties rather than the controller.
I have 1007.002 bios at the moment with the IDE drivers installed and NCQ disabled and I haven't had problems with it. I've had NCQ disabled since day 1 due to everyone's reported problems.
A lot of people are reporting NCQ works with 1007.002 and the latest drivers, might try turning it on.
vxspiritxv, if you decide to bite the bullet and enable it, could you let us know how you get on after a few days. You just volunteered to be a lot of people's guinea pig :)
I'm running:
Winchester 3500
2x512mb Patriot/PDP 3200XBL ram at 2-2-2-5-1T (206mhz)
1x 300GB Maxtor DM10
2x Leadtek 6600TDH
My machine went together great! Haven't had any problems with NCQ, even with the 1002 bios. I'm currently using the 1007-002 bios, but have used all of the other bioses except 1003. NCQ is indeed enabled and functioning. I've updated nVidia platform drivers to the nForce4 specific set with IDE drivers installed... still no problems with the drives.
Steve
thank you for all the replies. I had 1002, upgraded to 1006, wasn't sure about the 1007 cause it was a beta BIOS. Haven't had a problem yet with 1006, will run it and see what happens. How is the beta 1007? Stable?
lol, my chipset fan is going out. I just ordered a sunon magnetic levitation 40mm fan from
www.jab-tech.com to replace it. Will see how it works.
I just put an XP120 on my machine along with a Zalman passive heatsink on my northbridge. Working great so far! :) Just used a little rubbing alcohol to clean off the old junk on the northbridge, removed the protective pad, and applied a small bit of artic silver. Testing temperatures now:
It appears before... my CPU was running at 30*C idle... now it runs at 32*c load.
NB was running at about 30 idle.. now running at 26*C load.
Not too shabby!
Kylixz what setup are you running? My FX55 with an xp120 is running quite warm 55 loaded, but I can't find anyone who has a similar setup to compare to (see sig)
well I was hoping to get a lot lower temps with the XP120 and a 125cfm 120mm fan EVEn with the FX55 room warmer!
interesting problem, I tried copying from my IDE drive and it crashed my system every time. So I removed my IDE drive, unplugged my second SATA drive from slot two and redid windows with my main SATA drive. Now its up and running, I plugged back in my second SATA drive. Won't boot into windows. I put my second SATA drive in slot 4, it booted but I get access denied. put in slot 3, same. put it back into slot 2 and it booted into windows, but still get access denied. I have command queing disabled, 1006 BIOS, 6.39 nForce 4 drivers. any ideas?
