So I noticed that Dell FINALLY came up with a 22" monitor to bridge the gap they have beetween 20" and 24". Unfoutunetely its not an "UltraSharp" monitor, but a crappy TN panel. I realize that Dell are using a Chemi panel, but i guess its not one of their best ones. I was thinking it was the one on the 24", wich is amazing.
On the other hand, Asus has had a "pretty good" 22" monitor for a while now.. well at least in Canada.
Asus:
-Not a TN-panel.. possibly 8-bit?
-2ms response time
-No connections other than DVI/VGA
-No way to adjust the monitor
-Wastes space with silver line on the bottom
-Has Speakers wich are useless and make it less cool
Dell:
-TN-panel.. 6-bit crappiness
-5ms response time
Basicly, what I care about is Backlight Bleeding and an 8-bit panel. I guess I'll deal with the Asus having those unsightly speakers and non-black wasted space at the bottom.
I think it sucks that Dell finally make a 22" monitor and it sucks.. But that depends - I'm upgrading from a 17" Viewsonic VA712.. so maybe i wont notice a difference. I dont know if its 6 or 8 bit.
So what do u think? Does the Dell really suck because of its 6-bit of color and higher response time, or do they both suck and i should just find a way to steal a 24" ultrasharp?
Cheers,
Chris
Asus:
-2ms response time
Dell:
-5ms response time
Cheers,
Chris
