Hello everyone. I'm having a problem connecting the front audio panel connectors on an old version Coolermaster Praetorian to an ASUS M4A78 Plus motherboard.
According to the motherboard manual, the header can act as HD Audio or AC97, depending on how you toggle it in the BIOS. This is how it describes the pinouts. The "O" is the spot without a pin, where it would key if this were a solid connector:
Edit: Yes, the manual shows "PORT1 L" twice. I assume the bottom one is "PORT2 L". It's 2009 and still no one checks motherboard manuals for errors...
Unfortunately my case connectors are not labeled either way. They are:
Google searches have led to 404'd pages, unanswered posts, or answers that don't make any sense. Does anyone know which pins should go to which connectors, and whether I should be using AC97 or HD Audio in the BIOS? Thanks!
Code:
HD Audio:
PORT1 L XX GND
PORT1 R XX PRESENCE#
PORT2 R XX SENSE1_RETUR
SENSE_SEND XO
PORT1 L XX SENSE2_RETUR
AC97:
MIC2 XX AGND
MICPWR XX NC
LINE OUT_R XX NC
NC XO
LINE OUT_L XX NC
Code:
Ground
MIC Power
MIC In
L OUT
L RET
R OUT
R RET
Ground
