Asus mobo problems
Chris_B
Was transferring my uncles pc today into a thermal take soprano tower and a new antec 430 watt neo psu. Had the system up and running fine for multiple hours, we then plug in his usb hub to the top connector about 5 seconds later system just shuts off.
Thought i might have puled a power lead out, nope everythings secure, so i take the side panel off and notice the led on the motherboard is flashing green and not staying on constantly. I immediately think the psu has croaked it so i bring it home and test it on my pc, psu is working fine, i bring it back and try again, exact same issues system refuses to boot and the led on the motherboard stays flashing green. Ive tried resetting the cmos etc no effect.
Pc is comprised of the following
asus p4p 800 x mobo
2.8ghz (non ht) p4
1 gig geil value ddr
geforce fx 5200
winfast tx expert 2000
dvd rom
dvd rw
80 gig western digital hd
320 gig western digital hd
Really frustrated by this, especially as the asus manual that came with the board has nothing on trouble shooting or hints as to wtf a flashing green led means. :(
my a8n-e does this when i put my tv card in while the system is completly powered down and the p/supplydisconnected.what i do is take out the card,plug in the power supply and the green lite is lit solid,then i plug in the tv card and all is fine.try this with what ever cards you have plugged into it,video and any other cards plugged into the board.the compro tech support line sent me an email as to this problem,they manufacture the tv card.the power supply i have is plenty big as its a pc power and cooling 510 watt unit.try it and see if it helps you.........
