superkdogg
- Oct 14, 2004
Last night, I switched cases on the rig in my sig. I have a Fortron 450 watt psu (20+4 pins) and a generic firewire card as well as some hard drives (WD 1200JB, 2x WD800JB, 2xHitachi 80 GB SATA) in addition to what is listed.
The problem is that the rig was working perfectly prior to the switch. I disassembled it all and put it into the new case. Reconnect everything and take it back to the room where the monitor and peripherals are and turn it on. And push power button again. And push reset button. And swear, but none of those things seems to make the rig power up
After peeling off the side panel, I noticed that the mobo's green LED is not lit at all. It's supposed to be solid green if there is power to the board, flashing green in standby. Also, the NIC lights in the back are not lit either, so I know that there is a power issue.
The Asus website says that you should unplug the power cord and hold the power button for 10 seconds to perform a "power supply reset." I have no idea what that is, or why only Asus says to try this, but I did it and it didn't help. I also did not switch to 230 by mistake and tried it with the manual PSU switch in both positions.
Given that I highly doubt that in the course of changing cases I killed either the mobo or the PSU, what do you guys think might be the issue?
I'll probably go through the standard troubleshooting of pulling it out of the case, stripping to video and ram, then adding components one at a time, but I'm hoping that somebody can save me the hassle. Any suggestions?
