ASUS Mobo + Athalon Chip =X
matstars
I was building my computer last nite and after I plugged everything in (heres the two specs you really need to know):: from newegg
Mobo: MB ASUS K8V SE DELUXE K8T800 RETAIL
CPU: AMD 64 |3200+ ATHLON 64 RTL
it has a vocal POST.... when i plug it in and boot it up the POST tells me thru my speakers "PROBLEM WITH THE CPU...." so i figured that it wasn't plugged in right (socket 754s are kinda easy but u never know).... tried it again, same message, then i took the CPU out and wanted to see if maybe the CPU was bad (off the bat) and it says "NO CPU PRESENT"... has anyone ever encountered this problem? This isnt the first CPU i've built and Ive never had a problem before...
m.stars
First of all, it is not athalon. It is athlon. Always has been. Do you have another motherboard you could try the cpu in? That would be the easiest way to see if it is a cpu problem or a motherboard problem.
What video card are you using ... the voice genie is "CRAP" anc not worth turning on ... try a PCI video card if you have one ... This happened twice to me ... first one was bad PSU ... second one was a bad 9600PRO ....
i tried all that... pulled an old voodoo 3 out from the closet and plugged into the board with the radeon 9800 out... no boot :-\
if you start it without a VGA card ... does the voice genie reflect that?
took out both video cards -- "Problem with the CPU..." just the radeon - "Problem with the CPU" just the voodoo3 "Problem with the CPU" im thinking about returning the mobo/CPU to newegg and getting it from mwave preassembled
have you tried a different PSU? That's the only thing I can think of ... before RMA ... :(
